Eddie...PmPr
Almost there.....But.....
06 XRL
just got the edel mounted and needled @ 21e for 1,500ft.
17 clicks from full rich....2.5 turns out on the pump.
101mm 10.25 slug
airbox looks like swiss cheeze....
Blows a little black on start up...then clears up....(plug?)
let off thrtl between 60 > 75....higher end of RPM range....and she falls on her nose....almost uncontrollably:confused: .....then picks right back up and takes off. Got a little burp between gears when hitting them hard (pump tweak is at hand...) BUT...will the pump have anything to do with the fall on decel?
I'm thinking float possibly? 🙂
