Ohm test a coil-on-plug?
Should it be possible to ohm test the secondary coil on a coil-on-plug as any normal coils would? My coil ohm readout is now 'open circuit', and I strongly suspect it is broken. Just need to have it verified that it should actually be possible to do this kind of test. Bike is a Gasgas FSE450 '05.
Sure can. Just picture the COP as a regular coil, missing the high tension lead.
Primary coil resistance is tested via the pins on the connector, secondary is tested via the ground pin on the connector and the plug connection inside.
