HELP!!! DRZ400s Stator starting problem
I just installed a new stator in my 01 DRZ400s. I had isolated that the stator was the problem and now after the install it will not start. It started great just prior to the new installation. It turns over and has power at the iginition and all that, but it will not fire. HELP!
yeah starter works fine. No Spark. Not even trying to start.
When you say pick-up for the CDI what are you referring to. I got the stator from Electrosport and it has all the wires preconnected to it just like the OEM model. All I did was take out the old Stator and install the new one in exact same fashion. now it will not start. I am boggled. Why would the CDI be bad now? and not before.
ok looking at this pic I see that the stader and the "pick-up" would be replaced at the same time
the little thing on the out side of the flywheel
