alright, this is just a copy and paste from what i sent to the importer, but hoping y
whoops... well... now i know what happens when u forget to put a title in... anyway.
alright, this is just a copy and paste from what i sent to the importer, but hoping you guys might be able to help to. For those of you who didn't read my other thread, i stripped the mainshaft and am replacing it and first gear.
Alright, I assembled the main shaft then while attempting to put the whole transmission back into the cases, it wouldn't quite go. with the mainshaft in it's bearing (both bearings were still in the case) the countershaft wouldn't line up with it's bearing. when it would the two shafts would be angled apart and 2nd gear wouldn't quite be meshing correctly. Also, i was able to get the shafts to turn, however it's quite notchy. I figured it might have something to do with it being in 2 gears at once... or atleast trying to be. So i tryed to install the shift forks and couldn't get them in. I'm pretty sure i took them out before removing the shafts orginally but i'm not entirely sure. Any help you could give me here would be great, because i've tried just about every method my dad and i can come up with and right now it's close, but not quite there.
btw, it's an 03 beta rev 3 270 trials bike
nvm, found the issue, someone got lazy when they machined the new main shaft and the teeth for first gear arn't cut as deep as they should be.
