Dunes
so im going to the dunes this monday and there is a little slot by the side number plates and u can see the air filter in there. do i need to cover that up so sand doesnt get in? if so wut should i use? and also people say to put duct tape around the spring so that sand doesnt get in, do i put it vertically or horizontal?
thanks
I would use a filter skin for your air filter.Not to sure if cutting off most of your air is a good thing. I've also heard of guy's sticking foam in there like air filter foam.Maybe even oiling it a bit.I don't do nothing to them.If you have to remove your mud flap for paddle clearance I would defintely cover your shock.Theres shock covers you can buy but to get them on right I had to drop the shock to close the velcro all the way.Not sure which way to run the tape trick.🙂
