Headlight Replacement
I've spent the last few hrs with the search option and after reading a bunch of threads I still had a few questions.
The existing bulb was a A3603 which I believe is a 25/25w bulb. The bike has tags and a high/low switch on the bar and brake light so the bulb may not be stock. I have the plastic lens.
Stator is stock.
I may put in a LED tail light to reduce dimming.
I was going to switch to the Honda glass lens with the H3 bulb.
Is this a hi/low bulb? If not what other options do I have with stock equipment.
Other then the lens and bulb do I need anything else?
What is the difference between Hi and Low if both are 25 watts, do they both kick on when on Hi?
Thanks
hey on my baja designs headlight kit it has a 35/35 w bulb hi/low. this just means almost like a highbeam and low, i got pics of the high and low posted in a thread i made. you can see the highbeam shoots the light further wereas the low beam just lights up the ground.
Hope this helps
http://www.thumpertalk.com/forum/showthread.php?t=544890&highlight=baja+designs
