ssr 125-sx
Ive seen a few of these bike around at the races Look to be a decent entry level race bike its a 50 based bike with a alloy frame
Frame Type: Split rail alloy
Engine Type: 4-stroke, Single Cylinder, Air Cooled
Starting: Kick Start
Bore x Stroke: 54 x 54mm (125)
Compression Ratio: 8.5:1
Carburetion: Mikuni 22mm
Transmission: 4-Speed 1-down, 3-up
Final Drive: Chain
Front Suspension: U.S.D. Adjustable 5.5" Travel
Rear Suspension: 275mm Shock W/Adj. Rebound
Brakes: F&R Wavy Rotor Discs Brakes
Front Tire: 12"
Rear Tire: 10"
L x W x H (inches): N/A
Seat Height: 29in.
Wheelbase: 43in.
Ground Clearance: 10/12in.
Fuel Capacity: 1.0gal
Dry Weight: 136.4lbs
has anyone had personal experince with them?
I have worked on the 54X54 (125cc) Motors the older Versions, But heard from Jeremiah @ Staggs/SGR Racing that they have had a shifting upgrade (Improvement) and very good results
also I have serviced about 10 sets of the forks that come on those bikes..100% better when Serviced (fluid change)
other than that just what ive seen at the Track...:)
