Hanging throttle...
:) I need help what do i need to adjust when i give it gas and let go it stay reving for about 3 seconds im so confused.....
take apart the throttle assembly and lube everything up along with the throttle tube if you just got new handlebars then thats why it sticks or its just sticky
If cleaning does not work check the throttle cable by the carb. I had one starting to break, some of the small wires were broken but not all of them. Made it feel like it was sticking.
The dreadeded 'hanging idle ' can also be caused by a too lean pilot circuit. After you have confirmed the throttle itself is not sticking, try opening the fuel screw some, but no more than 2.5 turns from fully (and gently) closed
check the throttle position sensor by unpluging it chances are it need a new one or to be adjusted, if that doesnt work play with the fuel screw
