Location of part on this parts diagram ???
https://www.kawasakiepc.com/SSIConverted/865830_080816_073349_4663.png
The link above should take you to a parts diagram of a swingarm for a 2003 KX125. On the swingarm pin there is a "collar" on each side - part # 92152.
My question is, does this collar go on the inside of the frame against the swingarm or on the outside of the frame. I'm pretty sure that it is on the inside so the swingarm will pivot properly. I don't have the part or else I would probably know the answer.
inside the frame, it will sit inside a seal in the swigarm, and will but up against 42036 to give the proper "clamping distance" between the motor swingarm and frame
