ttr125 with yz 85 shocks???
hey, just woundering if you could really put yz 85 shocks on a ttr125 if so do you think it is worth it or does it make more sense to just buy a new bike???
thank you.:)
Yes you can. I have one sitting in the garage with YZ85 front shocks/brake setup.
thank you.:)
Yep, forks bolt right up...
but is it hard to put them on and what do u need just the yz 85 forks with shocks or more???
No it's not hard at all, the only thing you will need is a couple of washers (1 inch hole) to space out for the longer YZ stem. I just finished the swap on my bike, and I picked up an '01 YZ80 that had been taken apart for $200. I'm thinking of trying to fit the YZ swingarm and shock on my TTR as well. BTW... if you put YZ forks on a TTR you'll have to raise the rear suspension too, no problem though, just have to drill a 1/2" hole below the upper shock bolt and move the shock down. Hope this helps
