crf250x headlight on a 250r
is this possible? I also got to thinking that if I installed a baja designs kit.I just might be able to fit the light into the x's headlight shroud, If none of this is possible i'll just get an acerbis kit. any help is much appreciatted Thanks
yup, X headlight will bolt right up :) then when you get that baja design kit you dont have to stop riding when the sun goes down :riding:
If I just got a baja designs kit for it could I just switch out the headlight shrouds, as I think the factory looks better. If I got the kit with blinkers and everything, does it have a lighting coil. Also, will I need to have my stater rewound? what's the easiest way to do a conversion so that It's street legal
Trick dual sport is the best kit. the stock 35 watt head light sucks... kragens has a hid light for $100 and works with a 35 watt stator...
