pw 50 help
i bought a pw 50 today for 50 dollars got it to run its old don't now the year engine runs good but wont pull my son the bike wont even pull its self but when i put it on the stand the tire turns fast and works good but when my son gets on it. it don't run saw that it was shaft driven new to that maybe it needs some adjustments
did you turn the handlebar switch from start to run?
check the 2 shoe clutch pads for wear
yes i switched it to run were are the clutch shoes
yes or i get off the bike it bogs with its own weight but when i put it on the stand it runs great
I would say that it either needs a top end or clutch springs or both. Cluch shoes and springs are under the right side engine cover. You have to remove the engine from the frame to get to it. At least you have to unbolt it and move it forward.
not sure how i fixed it but the next day when i started it it ran
it was probably the switch sticking they are famous for going bad, keep an eye on it.
