when going out on HS
I went 1/4 out on high speed and was wondering what you guys think the difference equates to as compared to LS.
I certainly have to go in a couple clicks but is there a certain equation. In other words the 1/4 turn on HS has the height at speed I want but now I have to go a click or 2 to on LS get me around where I was for feel.
After the 1/4 turn I felt like I needed more compression when hammering through whoops because I started swapping more. :)
There is no set "ratio" but you will notice more of a change adjusting the H/S than the L/S. Make sure your sag and fork ht. is right too for stability hammering the whoops.
doc
Thanks Doc. Everything is set and I feel that after I backed off on the HS I now have to go in on LS because of the swapping. I'll go a couple clicks and see what happens.
