Fitting a supply for a GPS on my XR600R
Figured I'd write this up in case it was helpful to anyone else.
I wanted to tap a 12V DC supply off the bike so I could power my GPS unit, mobile charger or similar off the bike. Because it's all DC I figured I'd need to buy a single phase reg/rect and a large capacitor or a small battery pack.
After looking over the wiring diagram in the workshop manual and getting pretty close to buying a reg/rect I spotted that the bike was already fitted with one!
Seems that the euro bikes were wired differently and are mainly DC. Result!
After a bit of searching I found this thread which had the wiring diagram for an XR400 which was pretty similar to my XR600R.
I removed the headlight cowl.
Cut and spliced the green (negative) and black (positive) wires from the reg/rect tapping off a couple of new wires.
Checked out the voltage with the engine wired in (14V and I'd got the polarity right)
Then fitted an inline lighter socket and powered the GPS off it.
Seems to work really well though I won't be trying to draw any large loads off it given that I'm not sure what the stator is rated at.
It's a little dangerous to your GPS, if you make a big jump. It's better to put your bike on a stand and check the break cable.
Hi Rick. Good spot - that's something I should have spotted but hadn't done. The angle isn't as bad as it looks from the photo. The brake cable just rubs against the GPS mount a bit it doesn't loop over the top of it.
I did a bit of experimenation compressing the forks and lifting it on a stand and I'm pretty sure it won't loop over the GPS.
Nice write up, thanks.
No worries, always good to have feedback too 👍
