Ticking
A louder ticking sound is coming from the top end, I just did the primary nut fix and i am not sure if its the different oil i used, 10-40 synthetic or maybe my gasket did not seal correctly all and possibly the coolant is mixing into oil and that can be causing it to tick. I still have the acct (Mcct is on my dresser) and it wasn't making ticking noises before( except the sewing machine ones)
i fould the problem i went and drained my oil and it was a little milky so i am waiting for my new gasket so i can try this again. I also drained my coolant too.
What do you torque the 8mm side bolts down to to seat the gasket or set it?
Not supposed to run synthetic in her, clutch issues. Probably not related to tick though.
