Weird fuel flow issue...
Hi All. I've got a weirdness issue I thought I'd run past you on my 2000E. When I first bought the Z back in 2000 I immediately put one of those clear in-line fuel filters on it just before the carb (because I'm paranoid like that).
Anyway, my question is: how come the fuel filter doesn't stay full? When the engine is running, it eventually gets to where the filter looks empty. When you look closer there's just a very little bit of fuel in the bottom of the filter. It runs fine though and it's always done that. If you take the fuel line loose from the carb, the filter instantly fills up and gas absolutely pours out the line. After you reconnect and run the engine a little, it goes back to almost empty again though 🙂 . If I forget and leave the petcock in the 'on' position while the bike sits for a while it fills the filter back up too.
I guess it's a non-issue really, but it's kind of disconcerting seeing the filter empty. Is there some kind of back pressure on that line from the carb? Anybody else see this? :D
I've seen that on every clear fuel filter I have ever put on. On cars too. I guess it's normal?
Hi All. I've got a weirdness issue I thought I'd run past you on my 2000E. When I first bought the Z back in 2000 I immediately put one of those clear in-line fuel filters on it just before the carb (because I'm paranoid like that). :
Your not paranoid, ive done that too, noticed the same thing, but I dont worry about it! but it was difficult to get a filter small enough to fit in the space between the tap and the carb!
dan
