ok got my carb off & apart...HELP
took off my fcr carb, it wouldn't idle right(hanging up)& breaking up at high rpm's in 1st & 2nd...couple questions:
should I put any wd-40 in the top where the rollers are they seem to stick now
here's my #'s(I'm not sure what their called)
the pin is OBDXP there's 7 slots & it's in the middle
the 3 jets in the bottom are
45 this is the recessed jet
142 this is where the pin goes thru
65
the 2 jets on the side are
60
200
and the screw on the bottom doesn't have a # & it was turned out 1-1/4 turns
any advice or input would be cool
should I post this in the jetting section?
make the sure the slide plate is square end down.
change the 142 main jet to a 160.change the 45 pilot jet to a 48.move the clip on the needle from 4 to 5.
set the fuel screw at 1.5 turns.
wd-40 is fine for lube.
I didn't take the slide plate out(should I have?)
5 is counting from the top?
I'm running a cr83 plug will this still be good?
