my bike wont start after rebuild ><
i just put a new piston, rings and flywheel on my '06. i took my time and got everything together. i have spark and i cleaned my carb 3 times :) im at my wits end with this thing:banghead: when i kick it over it doesnt even sound like its firing it sounds exactly like i have a fouled plug
any ideas ?
Verify that the flywheel is correctly indexed by checking to see that the TDC mark lines up with the index when the piston is actually at TDC. Then recheck your cam timing.
Open the drain screw on the float bowl to verify that there is any gas in the bowl. Sometimes the float needle sticks shut. If the carb sat a while, the pilot jet may be plugged.
valve clearance??
ditto :) check compression
All a 4 stroke motor has to do is suck-squeeze-bang & blow. If you are missing any of those steps nothing happens
thats what i told my girlfriend she had to do :D
I forgot to add the part about throwing lots of money at it first. :)
hopefully you are a better mechanic than me:
I changed piston and rings (first time in a 4 stroke). When i flipped the head over to inspect the valves the lifters fell away from the valves allowing the shim to move on both exhaust valves. I put it back together 6 times before i figured that out. I had the timing right the first time. the bike sounded funny when you kicked it and would back fire like a bitch every 10th kick.
The Liberal solution to everything.
Funny as heck....probably one of the best smart @ss answers Ive seen..:worthy:👍
