kx85 power valve
Brought an 06 kx85, after having a little go on it I'd say the power valve comes in late. Can you adjust it on the 06 or is it normal that it takes a while on these smaller bikes? Thanks
its normal on the kx85, they are all top end,
If you can pull both covers get a can of carb cleaner (use small tube) and a small brush. Disconnect the actuating arm so you know when you're really freeing up the power valve. Some power valves can really get gunked up if not using good oil. My son said he noticed a huge difference after I cleaned it out real well.
