TTR90 Suspension
Has anyone done much with the suspension on the ttr90? My son keeps bottoming out. Mainly the rear shock. Is there something you can do? Can you get a stiffer shock?
I did the shock spacer on my sons. There are a few problems with doing that. It does give you a lot more travel. The first problem is the bike will lean over a lot on the kick stand. Second is that because of the increased range of the swingarm adjusting the chain is a pain. If you adjust it so it’s not too tight on the compression it is to loose and falls off when unloaded. The third problem is that your son will continue to grow and ride harder and harder. I have looked long and hard and haven’t found a fix for this. The best fix is to move up to a bigger bike. I made this mod and a month later was out shopping for a bigger bike.
BBR sells stiffer front and rear springs that work great. They are stiff though.
