CRF 250 idle problem
Hi, i have a 2005 crf 250r (stock) which wont idle since i fitted a new hot start cable,the cable snapped after a crash when i came to replace it i found that the cable and valve were seized so it probably never worked anyway because the bike started fine hot or cold. After freeing the valve and fitting the new cable the bike will start ok cold and idle with choke on but once warmed up will only idle with choke on and will only start with choke and the throttle slightly open.The bike revs up fine and rides ok but wont idle and stalls at every corner when the throttle is shut off.I have stripped and cleaned the carburettor blew all the jets out with compressed air, put fresh fuel in the tank, new air filter but still having no luck would be grateful for any help. thanks Paul
