Bike not getting spark every kick
Bikes is very hard to start due to its not spark ever kick it only does about one in four times. Its not the plug either ive tryed diffrent ones anyone know what this is?
Could be a number of things, try unhooking the kill switch , check all connections, should fire everytime u push the starter down with the plug out. I just recently had a cdi fail and the only time it would fire is when u touched the kill switch. Sometimes the best solution timewise is to borrow a buddys bike same year and make and switch stuff out until u find the bad part. Good Luck
in your service manual there should be a section for electrical troubleshooting. I have found it best to follow that. its not hard to follow and will help in if you follow the directions. i would recommend that you give that a try.
take the tank off and go through the plug in points. check the ignition coil. its open to all types of conditions.(corrosion)
