How much fork oil? 02 CR250
I no longer have my manuel and was replacing the seals on my trail bike when I came to a bump in the road:crazy: ......I'm wondering how much fork oil I need in the outer/inner. I'm 180lbs and mainly ride trails with this bike.
Would it be safe to put 285cc in the outer, and 192cc for the inner?
Thanks for the help
Brett
192 for the inner chamber. And after its bled and the cap on, cycle it right to the end of the stroke, and the excess will come out the holes in the top.
-- Edit -- just looked up the inner and it was 183ccs - doesn't hurt to use 192 and bleed out excess though.
Looked up outer chamber oil volume for you, its in below post...
Just looked it up in a manual that I happened to have on my computer, wrong language, but I found the fork oil level for you.-- it was for an 02 cr250
Max is 433 ccs - super stiff :D
Min is 337 ccs - really soft
Standard was 383 ccs
I would start at 350ccs and see how you like it. 🙂
