01 E fcr O-ring mod & slow air?
I have a stock 01 E fcr carb & I don't see how I can do the o-ring mod?
I see a lot of posts on removing the slow air jet, should I do this?
Hey Eddie, Thank you
You gave me the jetting advice last night on the same carb
you told me to go with the 160 main jet for the stock pipe
If I go to one of those slip on aftermarket mufflers, should I bump that up?
oh, I noticed on the fcr install post it says to run a 155 main jet for a stock pipe, is it because I have the OBDXP needle on 5th, I should run the 160?
Jim - your FCR39 needs the Taffy mod (instead of the o-ring) to limit the AP squirt. Search "taffy mod".
