06 crf 450 carb question
has anyone had problems with the carb. not getting enough fuel right off the
bottom ? plug check shows a slight brown tint to the plug like i think it should, can the pilot be too lean and cause this, also something about a leak jet ?that might be the wrong name as this is second hand info ! bike starts with ez but just doesn't like to take gas good with a quick twist of the throttle is there a simple solution ?
I have an 06 also... I had the Exact same problem....
I researched what to do, tried rejet etc.. no fix..
I tried a quick shot and adjusted fuel screw to match, and problem solved...
I can snap throttle while its on the stand and its clean and crisp.. ( once at OT i should add )
Also do you find it stalls when you snap the throttle off then on again in a corner ? The quickshot also fixes this..
You will recieve mixed answers !
The Quickshot and adjustable fuel screw worked great for me too. If you want to go a step further, have Tokyo Mods go over your carb. Good luck.
