i know im crazy
I know this sounds crazy but is it possible to but a turbo on a ttr-125l?
if so which i highly doubt tell me im crazzy but ill do it.
anything can be turbocharged, its just finding a turbo small enough that the engine exhaust will be able to spin the turbine. but ya anything is possible
you're crazy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!👍
Like others said it "can" be done, but why....
Think about "packaging" - where you're going to put the turbo (it's got to be high enough to drain oil back to the sump, out of the way of damage, etc.) Also are you going to do a draw-through carb setup or a blow-through? Can the engine handle the extra heat or are you going to need an extrnal oil cooler, etc.
Honestly - you're better off selling the bike and buying a 'racing' 2-stroke or a 'racing' 4-stroke with more HP and it would be a whole lot more reliable than a turboed TTR...
