08 x4r won't idle
What else have you tried? how many turns out on the air/fuel screw. Where do you have your idle screw set?
Have you made sure the carb was not dirty, fuel lines not kinked or clogged?
Whats your plug gap and its not fouled is it?
Does it start up and try to idle, or just not even want to run at all.
Will it idle if you are applying some throttle?
