Larger tank with Megabomb
Hey
I have a 2006 WR250 F and I've been using a IMS 3 gallon tank. I just bought the Megabomb header and it is dangerously close to that plastic tank... too close. Does anyon here have a Clarke or Acerbis tank with this header... I wanna know if they give any more space. Basically, if the tank extends much below the radiator, its too close.
Hope to hear from you.
Sam
you could try running heat wrap on the pipe that way it won't heat the tank up
Or maybe that reflective stuff on the tank, designed to keep the fuel cooler. Could be worth a shot.
That would be quite the pop.
3 gallons of gas on a glowing header in seconds. woah.
Thanks guys
I talked to Clarke and it sounds like their 2.8 gallon tank is a few inches above the header. FYI< the IMS tank is about half an inch from a megabomb. Since that thing gets up to like 800 degrees, its not good. I had already put the foil stuff on the tank and it had been burned through!!!. The megabomb needs space.
Thanks again
Sam
