Degreeing Cams
Hi all
I have a DR-Z400SMK6 with 10,000kms on the clock. Engine is original as made by Suzuki. I am in the process of fitting Hot Cams.
Before I start I have checked the cams as installed from new. The results are as follows.
Inlet
Duration = 219 Lobe centre = 109.25
Exhaust
Duration = 218 Lobe centre = 108.00
Checking done at 1.0mm. As yet not checked valve clearences as waiting for new gauges.
Do the above figures seem about right?
Thanks
Wayne
In New Zealand
Thanks
Then my method is correct.
Now I will install my hot cams and E base gasket.
Wayne
In New Zealand
