08 WR250 forks
Does anybody know if 07 YZ250 forks will fit and work on 08 WR250?
Thanks,
Thumpxr
You probably need the tripple clamps and probably a WR steer stem.check out after market trippleclamps if YZ will fit a WR. (I believe forks on WR are smaller than YZ)
should be the same diameter, but they area definately different on the internals. Pretty sure all WR's from 05' and after use the 04' yz250f forks and the yz's after 04' all use closed chamber forks. Worlds of difference in technology between the 2 types of forks.
Yes they will bolt on with no modification needed and I must say is a vast improvement over the stock WR forks in performance.
Thumpxr
