Headlight Removal
Just curious as to how many of you guys have removed your headlight and replaced with a number plate?
I love my light, so no, I only upgraded my bulb to make it even better.
Removed my headlight and replaced with nothing.
Ditto.
It's the "racer" look. :worthy: (click here for poser example)
Simply bolt back on/in when a light is needed...
Or, reach deep in the pocket and buy a Diablo HID from BajaD... putting that on only when needed. 👍
I ran with the light out for a long time and had no problems. I put it back in to use as a daylight to keep a load on the Baja Designs rectifier-regulator. I'm afraid to run it without a load since I've had stator "issues" already.
Cardboard and duct tape.. It can be done and look neat.
I have one plate for trailriding and one plate for racing.
Took mine off day 1. I'm running the R triples and front number plate. disabled the tail as well and put a R sticker kit over it. I'd run the R fender if I could have found a reasonable way to do it. Instead I think I'll just buy an R
I pull mine off for racing, run the Cycra plate. Did some mods and made two brackets from 16 ga. angle to attach the top to the stock mounts, bottom mounts via tie wraps to the fork tubes.
