2003 KLX 125 Valve adjustment
I am trying to find timing marks to set engine TDC to adjust valves, There is no timing hole plug in the engine to set the marks, Am I missing something here? What is easy way to TDC so I can adjust the valves, I have the specs just need to locate TDC.
you can get a flashlight, take the spark plug out and shine the light in the plug hole. when the cylinder is all the way up, there you are. This is not accurate enough for timing, however this will do fine for valves on this bike. if you cant see down the spark plug hole, a wooden dowel may be used to touch the top of the piston to find when it reaches the top of its stroke. (the dowel will not be pushed up any higher when your there) can the stator cover be removed? this is where you would normally find the TDC marks (usually marked by a "T")
