coolant overflow hose
i took out the foam because that just clogs the dirt even worse than without it and put the hose through one of the holes in the skid plate
I don't use the foam either. I too just shove the hose in the cavity between skid plate and motor, the only problem with this is you can not see if any coolent is being dropped easily
no foam. i just put mine through a hole in the front of the skid plate. its pointed right at the ground:thumbsup:
