1990 RM250 - New Carby? sorting old carby
Hi there
im looking at repalcing the carby on my 1990 RM250. Stock mikunu 38tmx has leaking choke and when leant forward 10-20 degrees leaks fuel.
Thinking of replacing it with a 38 PWK airstriker.
is this worth the money and will i notice much difference?
bike specs are below.
Riding conditions - 300 - 1000 feet generally - trail riding - tight single trail to wide open fire trials ... say average 805 humidity (south east corner of australia)
mods - completely rebuilt to to original specs, all bearings replaced, new big end, rod, piston (wiseco ist oversize), cylinder is steel sleeved, airbox top removed, boyesen rad valve, fmf expansion chamber, fmf powercore silencer, (edit) and a 10oz steahly flywheel weight
current jetting is stock
main jet - 370
needle jet - R-1
jet needle - 6AEJ1-63- 3rd clip
pilot jet - 50
float 14mm
running issue that is trying to be cured
- currently hard to start cold and leaks fuel when leant forward and to the right
thanks for your comments
cheers
dave
thanks for your thoughts.
also what are your thoughts regarding upgrading the carb to a PWK airstriker??
play riding .. yes ... woods riding ... a lot of single trail and some more wide open roads
seems very abrupt power delivery from closed throttle to about 1/4 throttle ... also would like it to idle properly
i thought that a newer carb would work better in the transition from closed to partly open throttle .. but mainly that it would be easier to set up to idle???
thanks for your responses .. much appreciated 👍
