Can't get my DRZ400 started
My 01 DRZ is having issues- here is what has happened:
1) Last spring bought the bike and it ran great for 3 rides. At the end of the 3rd ride it would crank but not start at all.
2) After that I couldn't get it started. I took apart the carb, it was in bad shape so I cleaned all out.
3) Bike still wouldn't start. It was not getting spark. I put a new plug in and after that the bike started right up and ran great. I rode it for a few hundred miles.
4) Then one morning I tried to start it and it just cranked and cranked ... would not start. It has not even made a sputter since.
5) I have checked the carb, tried starting fluid, hooked the battery up the a charger, put a new spark pug in... it is getting spark although it seems like it might be weak.
What could be going on! Any insight would be greatly appreciated.
Thanks.
Thanks.
A kink in a Vacuum hose?👍 Did you check the voltage on the battery without bike being under a load?
are the valves in spec ???
have you tried doing a comp test ??
tried removing the left side cover to see that the stader and flywheel are not trying to eat each other ??
The vacuum hoses are okay, I have not checked the valves or compression, but it was running great up to this point. How can I check if the stator is bad? The battery was weak when I originally tried to start it-would this be related to a bad stator. I've been hooking the battery up to a charger when trying to start it and it has plenty of juice to turn over.
Thanks for the help
W/ the carb. being hog dirty the last time, the pilot jet is suspect. That's the first thing I would check, and then valve clearance. Then the stator. How long did it sit this last time? Starting fluid should have made it at least pop I would think though.
If the first plug looked good but wasn't getting spark and then it fired after you put a new plug in, I'd suspect the wire going to the plug myself. Maybe buy a new cap as they are cheap and try that.
Just a thought.
