06 Base Settings for suspension
My buddy just PU a 06 450, does anybody know what the base settings are for the suspenders:excuseme: Any info you could give would be great. Thanks!!!! 👍
If tthe suspension is stock it wont matter because that bike is way too stiff at any setting .Go all the way soft on the comp. and see how it feels.I know because i have an 06 and it took a lot of valving to get it right.
You didn't give any informayion about your buddy or the condition of the 450... so figure out how many clicks there are for comp. and rebound for the forks and shock. Then set everything in the middle. For instance when you turn the comp. for the forks all the way out, then count the # of clicks all the way in and if you counted 20, turn it out 10. Do the same for rebound, then work on the shock and don't be afraid to make adjustments until you (he) find what works. I would set the high speed comp. for the shock at 1 1/2 turns out to start with as well. This should get you started!
