TT/XT/SR Engines Mounts
I just recently realized that there are indeed some small differences between Yamaha TT, XT, and SR frames (tank mount system is different on the SR for instance). Anyone know about engine mounting points? Will TT or XT engines bolt into an SR frame with no mods (and vica-versa). Seems like TT/XT engines are a bit more readily available than SR engines.
Yes the motor mounting points are all the same on those engines and frames. As you said alot of the other frame and tank mountings aren't but the engines will swap no problem. Ignition parts between XT TT(points) and SR (CDI) are just afew of the minor differences it the engines.
