Correction to valve/piston porting tool
Just a heads up.
A few weeks ago I posted some notes about porting and smoothing pistons/valves and may have noted in the thread, or follow up phone calls, regarding the proper bit used for this task.
The tool to use is not the #112 or #120 that I may have indicated.
The correct tool is Dremel #9911, which is a 1/8 shank "flame" shape tungsten carbide cutter.
I have tried various tools and cutters and have always found this one to be the best. Available at various specialty stores - just do a search for "Dremel 9911".
Sorry about the error.
Just a heads up.
You should be flogged 40 lashes with wet spaghetti!:worthy:
👍:busted:
