Check valve for tank cap? 510SMR
I have seen couple times about putting a check valve on the vent tube and rerouting out of the steering head. Any particular Part# for the check valve???
Don't do it especally on the FI models. Reason being tanks are now black and in the sun will heat up causing the tank to expand to the point the shrouds will pop off also the extra pressure can cause the fuel to push past the o ring and cause a leak around the fuel pump. Later George
Thanks for the heads up. For now I'm running it to the left side. Wondering if i should get a longer hose and run it away from my face. That's about where it is most of the time, front wheel being straight up and all.👍
