Oil Temperature Gauge for KTM 250 XCF?
Does anyone make an oil temperature gauge that fits the KTM 250 XCF engine, and if so, where can I buy it? If not, is there a way to adapt one to work? I tried Googling for it, but most of the hits I get are for HD, and a few for BMW.
I have the Vapor, and the gauge is for water temperature, not oil.
you unplug the water temp gauge from the tack, and plug in the oil one.
its just a temp sensor.
so just get the correct threading and oil sender(the sensor with the long wire) and hook it up.
OK, didn't think of that, Thanks.
np, but you won't have radiator temp anymore:eek: and your going to want to use the drain plug so there is oil over the sensor, if you didn't already know that:busted:
