Help with FCR Carb
There is a FCR carb for sale that has the following markings 5BE1 01MK1.0 can anyone tell me if thats the correct model for a DRZ400SM?
Thanks
do you have a pic?does it have a removable belmouth(adapter from carb to airboot)?
how do you attach pics. I am an idiot
go to imageshack or photobucket and post your pic there and then put in an image link on your post.
Yes it is the correct fcr carb . You also need the following parts to fit properly :
- 021-216 FCR Adapter 2 3/8", carb to S airboot
- 021-439 Adaptor O-Ring
- 017-262 EMN Needle
- 021-012 Airboot adapter bolts (2)
- P/N 13111-29F00 OEM Suzuki E Intake Manifold
- P/N 09402-58208 OEM Suzuki Clamp
- P/N 13685-29F00 OEM Suzuki Vacuum Port Nipple
i know TT sells the kit with a carb but is there somewhere to get all the swap parts if u already have a carb??
You can find
- 021-012 Airboot adapter bolts (2) directly from sudco.com
and
- P/N 13685-29F00 OEM Suzuki Vacuum Port Nipple from any suzuki dealer .
If you have the "old style"/E' model carb you also need 'E model cables , if you have the newer MX type your cables are fine .
