Fuel leak
I have a 2002 CFRF450R, and after I ride the carb leaks fuel all over the ground through one of the hoses. A friend of mine told me it is probably the float needle, so I bought a new one, installed it, and the same problem. Anyone else had this same probleme? What can I do to fix this?
check & clean needle valve seat with Qtip also check float level
have 05 and was having the same problem.
ended up being the float bowl was to high. bent the tab and was good to go.
nick
