Sand Woops Bike Set Up
When riding sandy Forida trails (Croom) with endless woops what is the best way to tune for suspension set up? Slower Rebound? Stiffer Compression? Do I mess with High Speed Compression?
i improved my rebound and it helped out quite a bit, raise the high speed compression on the shock and it should help too
The ones at or track aren't that big, but I just pin it. Make sure you try several body positions and riding styles before you mess with your suspension.
i realize you want to go fast threw woops but im asking more about bike set up. is a stiff set up better or do you want to go threw more of the stroke on the shock. fast rebound slow rebound? what works best for sand woops?
You want compression to be stiff so you don't bottom out, and a slow rebound so you don't get ejected.
And you dont have to "pin it" just keep on the throttle just a bit so your back end isnt all over the place. This just keeps the weight on the back tire so you wont get ejected :thumbsup:
