Galfer SS line question
i think the line would be too short . the master cylinders are different for the klx-r and klx-sr models same as the drz-e and drz-s models . i would assume the r model line is a little shorter than the sr line due to the way the banjo fitting mounts to the master cylinder . it more confusing when you check galfer part #'s between the klx-sr and drz-s , they're reversed:confused:
i have a galfer line on my s-model and its a tight fit with the caliper relocation bracket
