tubeless tires on mx rims??
OK, it's a long thread, but have a look at http://www.supermotojunkie.com/showthread.php?t=5090
If you want to skip ahead, see post #108 for very good instructions.
Keep in mind all this discussion was for spoked 17in supermoto wheels, but you might be able to use some of the info for your application. Something else to consider is that making the rimlock airtight may be the deal-breaker.
DTY
Is it possible to mount tubeless road tires on a mx rims? specifically 21" front and 18" rear xr600.
Yes - easy - using tubes.
Yes - harder - running as tubless (per the links above)
