High Compression Piston Re-Jetting question?
Not sure if this should be in the "jetting" section or not. move if necessary.
but after 12 or so hours a buddy any myself put a new crank, cam chain and new 13:1 high compression piston.
the bike started right up (3rd kick) we were worried though :thumbsup:
just from starting in up in the garage i noticed that it seems to be running lean, i played with the air/fuel screw but that didnt do much. its backfiring a little, and also the revs are hanging. like it takes a little whilte before the revs drop down to idle when throttle is cracked.
what would u suggest i change? main jet, clip etc.
thanks for any input here
I am not an expert on this high comp stuff but I know that the fuel mix will have to be changed on both main and pilot circuits. I am guessing that it probably wouldn't be more then one up on the pilot and some needle clip adjusting and maybe a richer main but not sure........anyone else?
thanks for giving it a go - anyone else?
can i get away with moving the clip only or is it the main now?
well i went up a jet size on the main and pilot. works great
until i broke my arm, again!
