jumping a 4 stroke
I recently swapped over to a 4 stroke and i was wondering if you revv the bike to all most full throttle off the lip will the compressin braking make the front end dive ive benn hitting jumps about half throttle.where are your revvs at when you leave the jump.
smooth acceleration will create a smooth launch...due to its engine braking if u let off it will nose dive...and is only compression braking when there is no load
I almost always land front wheel high and I looped out a couple of times on the landings. Its probably just my technique. At the track I went to, I rode the intermidiate track and almost all of the jumps I can clear in the top of 2nd.
