'01 KDX220R High RPM miss
On the '01 KDX220 I just bought, the bike runs great at low to mid RPM. I installed a Vapor instrument cluster on it and it cuts out RPM wise at about 6700 RPM. Would the installation of this Vapor have anything to do with the miss? Otherwise, what could be causing this high RPM miss? It's like it hits a rev limiter at 6700. I doubt that this is all the higher this bike will rev. An update, this bike has a newly coated cylinder from Fredette, new Wiseco piston, FMF pipe & silencer, and the Fredette bored out carb with Fredette jetting specs. This bike runs very strong low to mid but it's definitely an electrical issue at high RPM's. Any help would be, well, helpful.
Are you sure the power valve system is assembled correctly?
What I'd be checking is all the wires and the CD box, make sure theres no wires grounding (even though that would mean it would run like crap at all RPMs.) Also test the CD box, make sure it didnt go bad on you, and as said before if you did all the work, was the power valve system put back to how it orignally was? Even though it sounds electrical instead of mechanical, I'd check that stuff to.
when they bored the carb did they re-jet a little too rich?? If it was re-jetted..?
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By 02YZ426
      I thought it would be interesting to see what everyone in this forum is riding... So post them up
      Here's my 2006
      And my buddies 1996 KX250 that I just finished fixing up. Motor completely rebuilt and ready for the track.
