Metal Pipe Guard - HOW TO BEND/MOUNT??
I bought a pipe guard for my CR125 to help withstand the New England granite that I so often like to hit. My GasGas 125 has a carbon-fiber guard, and the last time I had a tipover into a rock, the rock punched through the guard like so much tissue paper. I decided that a metal guard was the way to go, and I choose a Moose "Pipe Armor" guard.
http://shop.thumpertalk.com/catalogs/Parts_Unlimited_Offroad_2007/default.asp?p=519
It's beefy - made from aluminum 1/8" stock (which is only 1/32" thinner than the Moose skid plate I got for the same bike), which leads to my problem. I CAN'T BEND THE THING!! The guard is pre-bent cylindrically, which makes it even stiffer longitudally - but the thing has to be bent into a compound 'U' to go around the pipe. I spent a few seconds beating it with a hammer with absolutely no effect.
HOW DOES ONE MOUNT THESE THINGS???
JayC
i have one similiar to that but I don't think it's as thick because I was able to bend mine. Do you think you could put one end on and heat it up some with a brazing torch and pull it in with the clamps?
Aluminum doesn't necessarily react well to heat/bend treatment. Besides, I think if you tried to pull it around with the clamps, either the straps would break, the pipe would collapse, or both, LONG before the guard bent.
JayC
A friend told me it took two people to put it in a vice and beat on it with a hammer to bend one to fit... And he's not a small guy.
JayC
Anneal that bad boy, the previous bending probably work-hardened it.
Dave
