friend got new bike
hey guys, my friend and i just went to go pick up is new ride....(brand new 2008 kx 250f) and we rode after and he broke it in so he went home and read the manual in how to change the oil....i ride a 2006 crf 250r so im used to having seperate tranny/engine oil, but he says he can only find 1 fill spot and two drain of course i though that there has to be another fill, im pretty sure all modern 4 strokes have seperate systems....any ideas? you guys gotta change your oil and someone has an 08 here....any help would be appreciated
and im posting this for him because he doesn't have an account and says he doesn't feel aking one.
This bike only has one fill and 2 drains. It is different than Honda. He can learn a lot of useful information from this site. I think it is well worth joining.
i could be wrong but im pretty sure the kx250f shares the engine/tranny oil. On the kawis there is only the one fill hole but there is the big drain plug and a little 8mm drain hole on the bottom. Drain them both and then fill it up with the amount of oil the manual suggests...i have an 06 250f so im not sure if its the same amount as the 08...hope this helped...and btw be careful not to strip the little 8mm drain plug...a lot of people had this happen to them!!
The only bike that has seperate tranny/motor oil is the hondas.
its your gear crap isn't running through your engine
Which is the reason for the small drain plug to get the oil out on the shifter side.
but you said they SHARE oil
ya nolan but its stil lubing the tranny
were not talking about that, with trannys the gears are gonna make mettal shavings, and more compared to the engine, so you wouldn't want them running through you engine, but now i realize that there are two sumps so the shavings wont run through the system, and that the oil from the tranny has to run through the screen and then the filter, so no risk
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
